1958 vacume wipers
If it is 1958 Buick related and doesn't fall in the other categories or you can't figure out where to put it, put it here! All non-1958 Buick discussion should occur in The Lounge.
Lawrence
1958 vacume wipers
Post by Lawrence »
Hi , has any one know what is wrong with the wipers if the operating lever will not turn them off . The cable is not broken or streached and and is operating the piston at the motor end . when the lever is pulled back to the off position it pulls the mechanism back at the motor end but the piston which operates the wipers remains in the on position . I have pulled it back to the off position manually and held it and the wipers switch off ,but as soon as I let go it moves on its own to the on position . Also the washers will not work every thing checks out no leaks or blockages . could this be linked to wiper problem
