Treadle vac conversion to newer master cylinder?
Posted: Sat Mar 16, 2013 9:31 am
Hi, I am giving up on the TreadleVac master cylinder I rebuilt, it pressures up somehow and causes the left front brake to stay on. I discovered if you reach into the master cyl with a screwdriver and push down on that valve sticking up, it releases the pressure. Has anyone ran intothis?
Now thinking I'll convert it to a newer, possibly dual master cyl...something normal. Does anyone know what master will fit on with the same bore diameter and fitting size for the brake line?
