valve covers
If it is 1958 Buick related and doesn't fall in the other categories or you can't figure out where to put it, put it here! All non-1958 Buick discussion should occur in The Lounge.
valve covers
Postby john » Wed Jan 21, 2009 8:03 pm
I am trying to remove the drivers side valve cover and the electrical connectors on the firewall makes this difficult if not impossible . How do I disconnect these connecters without damaging them? The top one will move but will not release.
john
Re: valve covers
Postby 58limited » Tue Jan 27, 2009 8:30 am
I just looked in my shop manual and it doesn't say that the wiring has to be removed. I've never had to do this to my car, so I can't offer much help. Hopefully someone else will have experience with this and post.
Re: valve covers
Postby Smartin » Tue Jan 27, 2009 7:31 pm
Can you "roll" the valve cover one way or another to get it to slide under the wire harness connector?
Smartin
Re: valve covers
Postby groundhog180 » Fri Feb 13, 2009 9:59 pm
Hi,
I see this post is a couple weeks old,but it is possible to play around and get the valve cover off without removing the electrical connectors. I had more of an issue with the power steering pump being in the way.
The connectors do come off by gently wiggling them.It's not easy though. A bit of WD-40 will help and won't hurt the wiring or plastic. Something like contact cleaner is hard on plastic.......Lee
groundhog180
Re: valve covers
Postby bhclark » Tue Nov 30, 2010 8:34 pm
I found it easiest to remove the carb and intake manifold, then I still had to loosen and pull the power steering pump out of the way.
Pain in the ass, if you ask me.....
Brian Clark
'58 Super 2 dr Riviera(SNOW WHITE)
'59 Invicta 4 dr ht (LUCILLE)
'65 Wildcat Convertible (ROXANNE)
'96 Roadmaster Estate Wagon (LIZZIE)
BCA #41596, DWD #3
bhclark
Return to Miscellaneous
Users browsing this forum: No registered users and 2 guests
