Crank pulley nut size ??
Postby ceejay » Sat Jan 02, 2010 9:48 am
Hi All,
My recently purchased Century has not run for over eleven years.
First I want to turn it by hand and make sure nothing is stuck before I try it with the starter.
Can some one please tell me what size of socket I will need to turn the engine by the crank pulley nut ?
ceejay
Re: Crank pulley nut size ??
Postby 58limited » Sun Jan 03, 2010 7:41 pm
Honestly, I can't remember the crank pulley bolt size. I THINK it is 15/16" but this might be the size on my Ford truck. Hopefully someone here who is currently restoring their car will answer this.
Postby dvonk » Sun Jan 03, 2010 8:11 pm
hey guys.
i just went out to my garage to find out exactly what size the crank pulley bolt really is. my 1" socket seems like a perfect fit. unfortunately, i do not have a 15/16" socket, so i couldnt check that size, but the 1" was fairly snug on the bolt--i.e., a 15/16" might be a little too small.
if anyone can correct me, please enlighten the group.
dvonk
Postby ceejay » Tue Jan 05, 2010 11:04 am
1" is correct
ceejay
Postby dvonk » Fri Jan 08, 2010 8:45 pm
good. did you get your engine to turn over?
dvonk
Postby ceejay » Fri Jan 08, 2010 10:16 pm
Nope... it wouldn't turn. We assumed it was the piston rings which would have been stuck and not the bearings.
The plan was to remove the heads while the engine was still in the car, free the pistons and then prepare to start it....
While dismantling the parts to remove the heads, I removed the valley pan and found that the pan itself had corroded right through at the front.
Inside, the cam and followers etc were nice and oily and looking like new but at the area where the pan had corroded, there was a lot of rust particles and other dirt which had fallen onto the cam and followers.
We then decided that it was too much of a risk to try to start the engine as this dirt would have gone into the crank case as well and we couldn't have cleaned the cam area well enough either.
Now I hope to dismantle the engine to pieces, clean it all up and re assemble it when we take the engine out once we start restoring the car. I am hoping that the internal components are in good condition and will not need all new parts.
ceejay
Return to Engine and Drive Train
